Hello all. I have a 1981 (although it is on an '83 Y reg plate which was the year it was imported from South Africa by its first owner when they moved to the UK) Spider in mid-restoration at the moment that seems to be going remarkably to plan! Probably spoken to soon though as it is going for it's MOT work and an engine strip and rebuild in 2 weeks. No problems with the engine just a precaution as I remember how expensive it was the last time I blew up a 1600 Coupe back in 1984. Normal cosmetic stuff needs doing, seats need attention, electrics need fettling, couple of small areas of bubbling stuff under the surface and a rather low quality re-spray to replace at some stage. Having bought one car that I had to scrap due to the severity of the dreaded brown suff last year, I'm hoping I've bought more wisely the second time around. I'll keep you posted.
