I travelled over to Lincoln today and spent a very enjoyable and instructive morning with GC. The good news is that my crankshaft passed all of Guy's measuring routines with flying colours, has been given the GC seal of approval and is fit for purpose. That was a real relief, I must say. It was instructive to watch Guy testing the crank for runout with it mounted on a pair of V blocks and a dial gauge on the centre journal. As far as I could see there was zero runout, and the only time the dial fluctuated was when Guy had to apply pressure to turn the crank. What surprised me was the degree of deflection when Guy pressed with only mild force on the centre of the crank - it registered 10 thou deflection. So the crank is with Guy now to work his magic.
I mentioned to Guy that I was taking the block to an engine reconditioner in Sheffield to have it hot washed, and he suggested taking it to a place that he uses exclusively for such work (and a lot of other machining operations). As I was only using the Sheffield firm because they were local, and the firm Guy recommended (Stanwood Engineering) were on the way back to Sheffield (they're based in Bawtry, about 20 miles from Sheffield), I was happy to take him up on that. I was so glad I did - they have a tremendous operation, with some hugely impressive computer-controlled machinery and they also do a lot of motorbike stuff, so I can see a variety of ways in which I can use their services.
They will definitely be boring the block to suit my new Vick Auto-sourced 10:1 pistons; what was particularly impressive was the way that Phil was able to assure me that there would be sufficient meat for my 84.4mm pistons in the standard bores when overbored just by running his fingers around the bore tops. Apparently bore # 4 is the worst, but they should be able to accomodate any slight discrepancy. The're having an open day on August Bank Holiday Monday, and are expecting a lot of classic cars and bikes, so that sounds like a must-see.
Stanwood will be knocking out the core plugs, hot washing the block in a solution that is completely friendly to the auxiliary shaft bearings, then ultrasonically cleaning the block, and finally facing off the top deck to ensure it's completely flat. With that done, it should be ready for boring to suit my pistons.
So - it finally feels like real progress is being made, after all the false starts.
