The 1300's MOT (more later.....!) necessitated a swap round of cars and taking the ie to Pudsey. Entering a fast bend I changed down to third.The gear was selected but the stick immediately went limp in my hand and no further gears could be found. After stopping for a think I was able to proceed to my destination in third gear, a great tribute to the torque and sheer grunt of the 2000ie engine.
It is possible to select gears at the gearbox end, and the linkage there makes a vague movement when the stick is moved, so some connection remains. Just seeing if anyone else has had a similar experience, and if so which part of the linkage had failed, or any thoughts?
I'll crawl under the car next weekend and see what I can see.
