Hi Paul,
I haven’t run the new fuel lines yet as the shell is still in primer. I removed the original hard lines that are routed inside the car and have made plans to replace them in 8mm copper in more or less the original positioning. The only real change will be the start and end points will be different as I am intending to go fuel injection, therefore flares and fittings will differ from original.
One change I have made is where the hard lines pass through the bulkhead. Instead of the lines squeezing past the throttle pedal, into the engine bay, and then squeezing past the end of the steering rack and up along the chassis rail I have chosen to go through the wheel arch near the bonnet release handle and along the space behind the front wing. Then the lines enter the engine bay through the inner wing to more or less the original position for the fuel pressure regulator next to the power steering reservoir.
Hope this makes sense. I’ll post some pictures when I get back in the garage. Busy decorating the house at the moment.
