Author Topic: VX gearbox dipstick  (Read 2669 times)
VX gearbox dipstick
« on: June 16, 2022, 06:37:33 PM »
Good day all,
A question for VX owners: where does the top of the
dipstick tube bolt to?
I suspect there's an additional bracket somewhere which I'll
have to make. I'm not even sure in which direction the tube points.
Thanks,
Offline hutch6610
Re: VX gearbox dipstick
« Reply #1 on: June 16, 2022, 11:40:07 PM »
Dipstick tube points toward the fuse box behind the end of the exhaust cam. Tube itself bolts via a L shaped bracket on the top end of the tube to what i can only describe as a triangular shaped plate that bolts onto the distributor adaptor at the distributor end of the exhaust cam box with a 10mm nut and bolt - its exactly the same as an injection car. Look at the back of the distributor and it should be there unless its missing?
« Reply #2 on: June 17, 2022, 05:13:58 PM »
Thanks hutch.
The gearbox is going into a carb car ,so no distributor up there. I'll figure out
somewhere to fix it to.
Regards
