I've mentioned to a few of you that above 30mph driving in a straight line something in the drive train of my Coupe makes an annoying 'whiring' sound. Even a slight application of left hand lock stops it dead, whereas application of right hand lock does not really effect it unless you are cornering tightly when the noise eases a little. The noise persists if you knock the car into neutral or drop the clutch at the above speeds.
I changed the gearbox and final drive oil (using both drains) for Red Line 75W 90 in July, and although this has improved the gear changes noticeably, it has not quietened the noise.
Chris M mentioned CV joins and I've tried a few full lock turns in 1st & reverse with no grumbling caused. As above the noise is at it's worst when driving in a straight line at speed, excepting the impact of left hand lock as above.
I'm sure a few of you will have a good listen at the weekend for me, but posting this as a heads up.
Neil
