Author Topic: VX Coupe resto  (Read 13530 times)
Offline lancialulu
Re: VX Coupe resto
« Reply #20 on: October 09, 2026, 05:57:09 PM »
So after a month and a half driving round Europe (in another Lancia) it was time to get back onto the VX coupe.
First problem it would not start.... I had fitted a newer and rebuilt carburettor before the summer break but had not run the car since then. I had no reason to suspect the carb as it is so simple (VX version) but I took it off just to double check. After carefully refitting it (no manifold leaks etc) I checked the valve clearance  and all were good - no tight valves.
I changed the plugs and it eventually fired up but only seemed to run on 3 (or 2). I rechecked the plug leads..... Nothing out of order. It also popped alarmingly through the carb on initial use of accelerator.
On Nigel's advice I checked that the cam timing was still correct (yes) and the ignition timing was OK c10deg at 1000rpm.
Cylinder 2 and 3 were dead but had good spark (changed over leads and further new plugs....).
I redid a hot compression test. This time all were around 160-165psi.
I am at a loss (although I suspect there is something going on with the head gasket between 2 & 3).
Any imput before I start tearing the engine to pieces (which will have to wait as I have a few smaller projects to finish first)??
Re: VX Coupe resto
« Reply #21 on: October 09, 2026, 07:11:33 PM »
Are you sure you have the timing right for the plugs as sounds a bit like wrong lead to wrong plug?
If compression is consistent then issue between 2 & 3 does not make sense.
Re: VX Coupe resto
« Reply #22 on: October 09, 2026, 08:21:34 PM »
You've checked the plug leads are going to the right plugs Tim but have you tried removing all four plugs and checking for sparks on all of them? You may have a faulty plugs or leads?
Try pulling the waterproof covers off at the distributor before inserting the plug leads in case they're not fully home?
Have you tried another distributor cap?
A compression test with those results doesn't indicate an issue between 2 and 3 as Nigel says.
Once reassembled try cranking the motor with the lights out in case there are a couple of leads arcing out preventing the plugs sparking?
Re: VX Coupe resto
« Reply #23 on: October 09, 2026, 08:32:41 PM »
Have you checked the sensor in the distributor? The wiring insulation has a habit to erode where the wire goes into the small sensor block causing havoc
Offline lancialulu
Re: VX Coupe resto
« Reply #24 on: October 09, 2026, 08:49:07 PM »
Well 1 and 4  are firing great and plugs come out white white electrodes. I suppose I could have got 2 and 3  wrong way round  - did check from dizzy cap several times....
Tim
Offline lancialulu
Re: VX Coupe resto
« Reply #25 on: October 09, 2026, 09:08:04 PM »
Well, am embarrassed to admit but 2 & 3 were swapped over… fired up sweet. 😤
Re: VX Coupe resto
« Reply #26 on: October 09, 2026, 09:23:17 PM »
Great result then! Easily done, I am sure a lot of us have done it.
Re: VX Coupe resto
« Reply #27 on: October 10, 2026, 12:27:03 AM »
we have all done it many times :-)  Tired and in a rush is my excuse
Online Nigel
Re: VX Coupe resto
« Reply #28 on: October 10, 2026, 08:15:34 AM »
Glad to hear it was something simple Tim.
Re: VX Coupe resto
« Reply #29 on: October 10, 2026, 08:24:00 AM »
yes, we've all done it... It's easy to get wrong especially with a distributor cap that isn't numbered to match the cylinders! Thank goodness the Alfa V6 12v has the markings!
Re: VX Coupe resto
« Reply #30 on: October 12, 2026, 01:00:23 PM »
And that is what swearing is for! Glad you found it and definitely one that we have all done.
Offline lancialulu
Re: VX Coupe resto
« Reply #31 on: October 12, 2026, 03:28:49 PM »
I made the elementary mistake of dizzy rotation..... and it all unravelled from there....
