Technical stuff => Part Number Requests => Topic started by: MattNoVAT on September 21, 2012, 05:50:29 PM
Hi Alan,
Can you confirm that this part number is the same for all S1, S2 and S2/FL Betas that were fitted with the manual steering rack?
RHD cars with TRW rack: 82310302 (Even though my parts book says the RHD manual rack is made by ZF !!)
Seems that LHD cars had two different makes of manual rack - so I would have to get confirmation from someone with both types that the damper bracket is interchangeable.
LHD cars with TRW rack: 82347363
LHD cars with ZF rack: 82347361
Matt
will try to check tomorrow
Sent from my MOMO11 bird using Tapatalk 2
my parts books specifies
damper 82321319
ser 1 82308220 trw lhd
ser 1 82310302 trw rhd
ser 1 82313044 zf lhd this one indicates berlina and hpe only
damper 82321319
ser 2 82347363 lhd ( note part is shown as modified 02/1979)
ser 2 82310302 rhd
there is no distinction between rhd and lhd given but the zf rack is again shown as berlina/hpe only but no bracket is listed
damper 82321319
ser 2 fl 82347363 trw lhd
ser 2 fl 82347361 zf lhd
ser2 fl 82310302 zf rhd
I suspect my s2fl parts book is missing an update to correct the zf rack error!
apologies but i am still temporarily unable to access the microfiche I have s2fl and s2fl2 fiche so will check those as soon as I can
Hi Alan,
So both the damper and damper bracket are consistent through the evolution of the RHD range.
Thats perfect thanks!
it seems so but as with everything about Betas the info is a bit confusing, will try to check the microfiche in case of any differing info for later models
