Technical stuff => Heating/Cooling => Topic started by: lukasdeopalenica on October 14, 2013, 01:13:26 PM
Guys,
Is the water pump the same for all beta engine types? I found one, but it is specified only for volumex (Graf PA168) Is that correct?
Proper Vx pump has deeper impeller than for other models but most after market suppliers list all as the same. I don't know 100% if vx pump is OK in non vx block or not but suspect it is. Correct vx pumps are difficult to find! They are same as Monte Carlo by the way
Thanks. Do you mean the v-belt line is different?
No it's just the impeller is deeper
