General Category => General Discussion => Topic started by: rossocorsa on April 06, 2015, 03:33:26 PM
Title: Trying to build a list of all UK VX coupes
Post by: rossocorsa on April 06, 2015, 03:33:26 PM
Can anyone add to the list on the line below? I know I'm a sad case but I've been trying to build up a list of the alleged 150 UK vx coupes, not done too bad so far but some cars clearly had cherished numbers at some point so may have been duplicated, also some records these have been lifted from seem to have possible typos
https://www.dropbox.com/s/46b1pwfk1kk28y8/vx%20coupe%20updated%20apr%2015.xls?dl=0 (https://www.dropbox.com/s/46b1pwfk1kk28y8/vx%20coupe%20updated%20apr%2015.xls?dl=0)
Hope the link works having problems copying Dropbox links for some reason
Title: Re: Trying to build a list of all UK VX coupes
Post by: Neil-yaj396 on April 07, 2015, 06:59:10 AM
The link doesn't work for me. It says I may need to sign in?
I'll have a look for VX Coupes listed on the LMC Database, but that is all self declared, so probably pretty limited.
Post by: rossocorsa on April 07, 2015, 09:38:01 PM
updated the link does it work now?
I built up most of the list quite quickly by trawling old information and then cross referencing with dvla road tax site and other publicly available searches such as www.cartell.ie (http://www.cartell.ie) occasionally another car pops up on ebay, in old photos on the 'net etc.
Post by: Phil on April 07, 2015, 10:48:25 PM
B520DGO is mine & is currently on the road, I'm pleased to say
Post by: rossocorsa on April 07, 2015, 11:13:46 PM
Good to hear, the status listed on the spread sheet is really just a snapshot of whenever I added an entry I've been compiling this for some time. When I've time I will add month and year of build (if I have the chassis number) and first registration(if it still shows on dvla)
Post by: peteracs on April 08, 2015, 08:16:55 AM
Sorry to hijack the thread, but just wondered if anyone has tried to do this for the any other model, e.g. Spyders in UK?
Post by: rossocorsa on April 08, 2015, 07:55:10 PM
Never heard of it, looks like you might have volunteered ;-) I started on the vx coupes list partly because I knew there shouldn't be too many but also out if an idle curiosity but then found that I could list far more than I expected! The irony is of course that with probably one press of the button dvla could list this info in a couple of minutes.
Post by: HFStuart on April 08, 2015, 08:44:55 PM
I made a start on a list for all. Mainly this was to keep track of the cars that pop up on eBay etc but it could be fleshed out to include all those we're aware of without too much trouble.
I've included as much data as seemed sensible:
1st Registered
Chassis No
Engine No
Registration
Model
Engine
Transmission
Series
Colour
Mileage
Status (ie For sale, In use, SORN, Scrapped)
Condition
Modifications
Notes
Current Owner
Owners Contact   Location (Country + County
Last change in Status
Advertised Price
Not all data is available for all cars but that should cover most eventualities. I'd thought of asking Tony to put an online form together but people could just as easily pm me with details of cars.
Thoughts?
NB I've decided it should be called the 'Betabase' !
Post by: rossocorsa on April 11, 2015, 02:23:06 PM
just a reminder to all that I do have all the available build date data for Betas and am able to give month/year of build for most cars built 78 onwards also gamma and monte in some cases
Post by: TonyLanciaBeta (Tony Harrison) on April 12, 2015, 06:42:37 PM
Hi Stuart, you may remember back in 2011 we talked about creating a database.
I knocked up a test form at the time see http://www.lanciabeta.co.uk/betabase.htm (http://www.lanciabeta.co.uk/betabase.htm)
Just tested it and it seems to work, emails both you and me the filled in form.
I can edit the page to suit, let me know what people think
Cheers Tony
Post by: HFStuart on April 12, 2015, 06:47:37 PM
I'd forgotten you'd got as far as doing the form for it.
Let me have a look at that and get back to you.
Post by: Neil-yaj396 on April 13, 2015, 06:23:00 PM
I can only find six VX Coupes on the LMC database, all of which you will be glad to hear are on your list and stated as on the road. According to the database A98CDB was however exported to Australia at some point.
Post by: rossocorsa on April 14, 2015, 07:49:26 AM
Thanks Neil
Most of my info was pulled from old LMC registers, I did not record owners though just reg numbers from which I could then find colour on dvla ( if they are still listed some have disappeared) and could confirm as a VX by also checking on cartel.ie I've lost the link where I pulled the chassis numbers from but it was some sort of support site for motor factors that allowed you to look up reg numbers and find vehicle details, not 100% as not all cars were listed there.
Post by: dozza on July 06, 2015, 10:06:45 PM
Hi all,
I am a proud owner of a VX coupe and have just read your thread regarding listing them all.
Thought id just let you know she is still with us.
Her Reg is B190 VCX, have owned her since Oct 2009 but had been unable to get her back on the road until now.
She goes in for an mot tomorrow ( tue 7/7/2015 ) after having new outer sill, loads of rust removed and repaired on inner sill,
welding to the square locating plate for the assembly line.
New discs and pads allround, couple of new brake pipes, set of new tyres and a clean out of the carb.
Previous works have been carb rebuild, new cam belt and tensioner and a couple of oil leaks fixed.
She has 79,000 miles on the clock and is in ok condition, will hopefully be able to use her at long last for the remainder of the summer.
Plan to get a bit done each year, ( other outer sill and inner sill etc ) as the wallet permits.
Hope this helps your list.
Regards
Lee
Post by: Neil-yaj396 on July 07, 2015, 07:03:05 AM
Great number plate for a VX!
Post by: rossocorsa on July 07, 2015, 07:59:11 AM
Agreed Neil, nice to see another one alive and well. On the subject of number plates in an attempt to inspire me to finish mine I bought the reg A2 VXB for it (currently it's A628TYK) might still be some time before it is finished though.....
Post by: dozza on July 08, 2015, 07:21:55 PM
Cheers for the number plate flattery guys.
It came with the car, not sure if its original.
No news on mot yet, fella really busy at mo, fingers crossed for this weekend.
Will keep you posted.
i noticed on the members car page a black coupe with what looks like delta integrale alloys, can anyone help with the wheel size etc, it also looks like it has been lowered, liked the look, liked the fact they are possibly lancia alloys, can anybody shed any light on this set up please, would also like to be able to bolt the original cromodoros  back on, any info would be much appreciated.
Thanks in advance.
Post by: dozza on August 02, 2015, 10:16:40 PM
Hi all,
B190VCX is now on the road!
Apologies for not posting sooner, couple of small issues delayed the MOT.
Collected her yesterday (1/8/2015), massive smile, massive thank-you to the fella that repaired all the rot ( Mark @ IRS ) and ironed out all the niggles.
Possibly been 20 yrs since ive driven a Beta Coupe thats running right and its brought back all the memories.
Loads more to tackle but will carry out as much as the wallet permits each year to bring her back to a decent standard, at present just happy shes back on the road and useable.
Roll on the weather, sun and more sun, so i can enjoy it as much as poss.
Regards
Lee
Post by: flex on August 10, 2015, 05:27:06 PM
I can confirm that A164DPJ has been hibernating for the last 23 years after a respray, In need of finishing and recommissioning.
Post by: squiglyzigly on August 21, 2024, 06:37:37 PM
Are you still collecting VX coupes. I didn’t realise this post existed.
Mine is very much alive and kicking.
A896ARD BLUE (originally red at production)
Post by: rossocorsa on August 22, 2024, 08:18:35 AM
I'd forgotten that I posted this 😂 I must admit that I haven't updated this for years!
