Technical stuff => Suspension => Topic started by: mwredit on July 02, 2017, 12:54:12 AM
Title: Socket for inner cv flange nut
Post by: mwredit on July 02, 2017, 12:54:12 AM
Does the proper Lancia 4 point socket exist for the driver side cv inner flange nut?  I just renewed the passenger side output seal, which was easy after removing the center shaft and would like to do the driver side seal.  It isnt leaking, but would like to replace anyway.  Suggestions?
Title: Re: Socket for inner cv flange nut
Post by: rossocorsa on July 02, 2017, 07:46:10 AM
They do but you would be lucky to find one easiest to buy a suitably sized budget priced socket and modify it by cutting the castellations into it
Post by: peteracs on July 02, 2017, 03:50:31 PM
If you get no response on here, you could ask on lancisti.net if anyone in the US has one, failing that then the solution Alan suggested is probably the way to go. If you were in the U.K., The LMC may have one as they have a number of the Beta tools.
Post by: mwredit on July 05, 2017, 12:14:45 AM
I'm into modifying a suitable socket.  I'lll do that.  Thanks all.
