Technical stuff => Engine => Topic started by: DARREN BETA. SPYDER on March 14, 2019, 07:56:45 PM
Title: cylinder head
Post by: DARREN BETA. SPYDER on March 14, 2019, 07:56:45 PM
hi , question - will a delta intergrale cylinder head fit on a beta block
Title: Re: cylinder head
Post by: rossocorsa on March 14, 2019, 08:16:07 PM
Not a simple question remember that the head is reversed, exhaust at front
Post by: peteracs on March 15, 2019, 12:09:56 PM
Hi Darren
Can I ask why you would want to?
Post by: DARREN BETA. SPYDER on March 15, 2019, 05:59:46 PM
i,d seen one that was already ported with bigger valves., i,m going to see a chap tomorrow though about getting my engine bored for oversize pistons ,and getting my original head ported 43.5 inlets new cams and gas flowed
Post by: rossocorsa on March 16, 2019, 09:49:29 AM
Another option is to start with a VX head
Post by: DARREN BETA. SPYDER on March 16, 2019, 12:45:56 PM
sorted ., build on way now, 84.8 pistons , mild road cams , ported and gas flowed , and 43.5 valves, lightened flywheel . next step twin 45s to source
Post by: betabuoy on March 17, 2019, 08:39:29 AM
Darren
If you’re interested, I have a rather nice ported head that’s now available. Originally from a 132, it’s had the inlets opened to 43mm and has had a proper porting job done that would be very good if you’re running 45s. It was built for a monte some time ago but spent more recent years on a grass track racer. The cams are reprofiled but I can’t give you an accurate spec and anyway I think you have your own cams in mind.  I’ve removed 2 of the valves, for inspection purposes only, but they’re all nice and straight and the pressure test was spot on.  Just let me know if this is any good to you otherwise I’ll put it on eBay shortly.
Post by: DARREN BETA. SPYDER on March 17, 2019, 08:53:43 AM
thx chris , i have now given head and block to recommended  knights engineering in nether heyford , should be back to me in 3 to 4 weeks,  i need to order  the right 45s carbs now, i know there dcoe but thats it ?
Post by: betabuoy on March 17, 2019, 09:10:48 AM
Darren
Demon Tweeks seem to do a ‘reasonable’ price for Weber 45s, plus your choice of linkage, but jetting will depend on what spec (CR etc) you’ve chosen. Have a chat with whoever you choose for the rolling road final setup and they should be able to advise; for info, GCRE always recommend Northampton Motorsport for that bit. They’ll be my chosen team once my engine’s ready... probably late summer.
Post by: rossocorsa on March 17, 2019, 09:54:47 AM
If you are very pedantic for the right period look you need a nice pair of used refurbished dcoe as modern ones aren't made in Italy.
Post by: betabuoy on March 17, 2019, 10:15:08 AM
You’re absolutely right Alan. And I’m leaving that purchase until last so please do let me know if you’re aware of anything good out there.
