Technical stuff => Exhaust System => Topic started by: peteracs on June 06, 2020, 11:52:46 AM
Title: Manifold to exhaust down pipe gaskets, what is needed?
Post by: peteracs on June 06, 2020, 11:52:46 AM
Hi All
Just looking at the parts book and confused by exactly what should be there.
The manifold to down pipe also has a plate which attaches the exhaust shield, but in the parts book it is unclear if I use one or two gaskets and if one is different to the other. I have some of the metalised gaskets and think I have a more fibre based one. So can anyone confirm what gaskets I should use?
Title: Re: Manifold to exhaust down pipe gaskets, what is needed?
Post by: Neil-yaj396 on June 06, 2020, 05:07:31 PM
Just one gasket plus the heat shield in the ones I have changed (1300 and 2000).
Post by: peteracs on June 07, 2020, 08:30:18 AM
Hi Neil
I assume then the order is manifold/heat shield plate/gasket/down pipe, looking at the exploded parts diagram?
Just seems a little odd having the metal of the manifold mating to the metal of the shield plate, I may put some exhaust sealer between the two.
Post by: Neil-yaj396 on June 07, 2020, 07:11:32 PM
Yes, that's the order I've replaced them in.
Post by: peteracs on June 07, 2020, 07:41:20 PM
Thanks Neil
