Technical stuff => Fuel System Carb => Topic started by: capriblu on January 09, 2021, 08:19:06 PM
My Car (2000 Coupe) generally runs very smoothly but I have struggled to get idle quite as smooth and stable as I always remember being to achieve with these cars many years ago. I have a couple of different DAT /DATR 250 variant carbs that I have tried and all are similar. I'm confident that ignition timing, no air leaks, spark etc. is all good and I'm starting to wonder whether changes in fuel quality over the years have started to make the original jetting a bit marginal?
Has anybody got any experience or thougts on this?
I'm tempted to try some slightly larger size idle jets.
Presume both the primary and secondary idle jets will affect tickover (as well as low/medium speed and load running)?
What are the standard jet sizes?
I notice in the Haynes Manual (never a great thing to rely on!) that different main air correction jets on the secondary are shown for DATR variants with 1.50/2.10 and 1.5/2.40 (main/air corrector) the former for 1600 and the latter for some 2000 cars. This seems quite a difference?
Also quotes a 1.00 mm idling jet on secondary for earlier DMTR (1600/1800) v 0.8 on the DATR both for the same 0.70mm air jet size?
Any sage advice welcome .......... ???
Out of interest, what petrol are you using?
To rule out the ethanol influence you could try the Esso 99 which according to them has no ethanol in it.
Also a few experiences with dirty idle jets needing a good clean.
Also any chance the float is not floating as it used to?
There was also on the LMC forum an older carb where the end of the idle metering needle had become deformed and needed to be reformed.
Just my 2 penny worth...
Thanks Peter,
Issue is very minor really but I know all fuel is very different now. Ive also read that the Esso 99 is ethanol free so i may try that. I generally use Shell Optimax.
I think the settings originally were never super generous in the lower speed / load range. The jets are clean and the mixture needle is good with a new rubber o-ring seal. Ive checked and re-set the floats a while ago but this shouldnt really affect idle or low load. I think I'm just going to try a few different idle jet sizes in 0.05mm increments and see if I notice anything .......
I have no Lancia-related information, but I do know that carburetted motorcycles from the late 80s benefit from larger idle/pilot jets and probably also main jets. My 1988 VFR750 was much more responsive when I went up one size on the pilot jets.
My primary stage was increased by the Aldon guys following the rolling road session. Now if I can just find the paperwork........
I've something in the back of my mind that bigger jets are the way forward as petrol is more "diluted" that when the cars came off the production line. Increased jets compensates for this. however .. . . I can't find the original source of this so anecdotal but interested if anyone else remembers the article
Update
So with 20 litres of fresh Shell Optimax with a splash of Millers VSP I set about trialling different jet and air corrector cap sizes.
Before my new items arrived I had already tried running the car with a spare standard 0.8 secondary idle jet on the primary side. This made a noticeable difference to pick-up and general feeling of responsiveness from low engine speeds but obviously a bit of a big jump from the 0.5 standard jet size.
I tried the same experiment with a spare carb (both DAT 2/250s) and found exactly the same behaviour. As well as the general difference in feeling of responsiveness when actually driving then, again for both carbs sudden blipping the throttle at rest with a standard 0.5 idle jet (I tried two different 0.5 jets just to be sure) seemed to be met with a very slight but nonetheless discernable fluff/miss. This disappeared with the 0.8 jet. (Ignition fine and timing checked). I was still able to keep CO at idle reasonably steady at around 2.5/3.0%.
So my new jets and air corrector caps arrived. (About £30 worth from Eurocarb).
Firstly I tried just changing the primary idle jet. A 0.6 made a very big difference over the standard 0.5 but car still didn't seem to pick up just quite as well as a 0.8. Then tried a 0.7 and this felt good. Perhaps a 0.65 would be optimal.
Subsequently took a punt with a selection of the few items that I purchased and went for this combo -
Primary Idle 0.7 instead of 0.5 standard
Primary Main 130 instead of 120 standard, kept standard F30 Emulsion Tube, Air Corrector Cap 160 instead of 170
Secondary Idle 1.0 instead of 0.8 standard (doesn't seem to be anything available between 0.8 and 1.0)
Secondary Main 155 instead of 140 standard, kept standard F30 Emulsion Tube, Air Corrector Cap 225 instead of 240
With the above the car is absolutely transformed. Absolutely no wooliness around transition from first to second choke and just seems smooth and strong throughout engine speed range with only a slight second choke kick which just suggests better power lower down rather than any loss at the top.
A few short speed runs on some familiar stretches confirmed that the car is noticeably swifter and seemingly freer to head towards redline.
I could "back-off" from this combo slightly to see at what point performance/response starts to fall but for the time being I'll stick with this and see how the car performs on longer runs. Hopefully MPG will still be sensible. I checked the plugs after a 30 minute run and all nice and light brown.
I always felt the fuelling on the 2 litre cars to be marginal and this along with the advent of current ethanol containing pump fuels probably means the original standard jetting is now seriously inadequate.
Really pleased - car is just so much better and quicker!
I had an early F/L HPE 2000 as a daily over 25 years ago and this drove similarly. All the other 2000 Betas that I have driven have suffered from very slight first to second choke "fluff"to some extent. This effect could often be eliminated by retarding ignition very very slightly but at the loss of top-end performance. Shortly after I bought my HPE Chris Bastow/Betacar rebuilt the engine with HC pistons - I'm wondering if the Carb was re-jetted as well!
Excellent stuff! I will at some point be replacing the standard Weber on my Spider 2000 with a pair of DCOE 45s with 36mm choke, but until that happy day I think that uprating the jets as you have done will make the car much nicer to drive. Where did you source the jets from?
<Edit> - Just re-read your post and noticed you used Eurocarb. I'll speak to them in the morning.
Just found this useful calculator. Also has good descriptions of what the effect is of increasing or decreasing values (ie smaller choke)
https://www.carb.parts/calc (https://www.carb.parts/calc)
I'm resurrecting this thread as I have the jets that capriblu recommended ready to go into my DATR carb, currently stripped down on the bench. My problem is that I can't see where the jets are in the carb body. The main jets are (I believe) located underneath the emulsion tubes but I can't see any way of getting them out from where they are buried. Similarly, I have no idea where the idle jets and air corrector jets are located or how to remove/replace them.
The carbs are currently in the state pictured in my recent thread in this section.
All help gratefully received...
When you unscrew the emulsion tube it usually comes out with the main jet still attached to the bottom of it - the air corrector is on the top that's the bit with the screwdriver slot in it. They can be a pretty stiff fit and you may not initially realise that it's three items rater than one.
The emulsion tubes are the inner brass screws - the idle jet holders are the outer screws - remove them and again the idle jets should come out with them, occasionally they get left behind in which case a small drill or rod can be used to wiggle them loose before retrieving with needle nose pliers or in your case turning the carb upside down.
These photos show it quite well
https://www.flickr.com/photos/55777341@N00/5464599813 (https://www.flickr.com/photos/55777341@N00/5464599813)
Fantastic stuff - thanks so much. I would never have known there were so many parts ostensibly in one. All the bits are in the ultrasonic tank (again) so that may very well shake them loose...
Thanks again.
On and off as detailed in several threads my car ran like a dog and I'd always planned to change the jets. Once the carb was fully rebuilt all these issues seem to have disappeared even though the original jets were just cleaned and replaced. I think a lot of problems come from the many drillings in the carb body that get blocked. Hopefully your ultrasonic cleaner is industrial enough to have shifted everything.
My Coupe did 1200 miles in 3 weeks totally glitch free and now runs very smoothly, particularly during motorway driving, which it didn't do before.
I took Capriblu's advice and just swapped my "lucky dip" parts for the ones he recommended. Definite improvement.
Sourced from https://www.dellorto.co.uk/ (https://www.dellorto.co.uk/) in Pangbourne, Reading. Just a FYI, their emulsion tubes are about half the price if you buy from their eBay store rather than their own web site. https://www.ebay.co.uk/str/eurocarbdellortoandwebercarbs (https://www.ebay.co.uk/str/eurocarbdellortoandwebercarbs)
My experience with the 1600 DATR is that it works fine as standard. It did have an Ultrasonic bath and getting the float level correct has been a bit hit and miss, but the engine does not hesitate etc and if anything runs a bit rich which is most likely float level related.
I'd read Capriblu's comments and suggestions and thought 'what have I got to lose?' - increased fuel consumption, perhaps. His setup was the same as mine - S2FL Spider 2000, and I'd always noticed the symptoms he was describing so I decided to give it a go. I believe that 2000 and 1600 DATR are jetted differently, so that would affect the end result. Taking the carb off for the jetting changes and ultrasonic bath has also exposed a number of other issues that needed fixing, so if only for that it's been a worthwhile exercise.
Once the car is (eventually) running again I'll report back on findings...
All the later 2.0L Carb betas that I have driven have to some greater or lesser extent suffered some discernible fluff/wooliness around the transition from first to second choke (with ignition timing at nominal settings). I don't think the jetting on the 34 DAT/DATR type carbs was very different if at all for the 1600s so might explain why this common issue seems to just affect the larger capacity engine?
Another albeit minor factor compounding the above is that modern E10 fuels will require typically 4-5% richer fuel/air ratio settings than ethanol free fuel.
Have taken my car on some good long runs and trips over the last 12 months on the jetting combo that I posted above and can report that car continues to perform much better and more smoothly. Fuel consumption certainly hasn't suffered, if anything I'd say it seems slightly better than previously; even on "spirited" runs I estimate I'm seeing at least 27 Mpg.
I've gone for your recommendation and had the car at L&M to get timing done, check carb and a few other bits. Agree it drives much much better as a result (and thanks to L&M), however I did have a question. If there is a richer fuel delivery due to jets, and you then apply choke, doesn't that have double the effect on the mixture, i.e. over-choking?
Hi John
Are you confusing cold start choking, where a flap comes over the primary choke tube, with the two choke tubes?
Update
@capriblu I am going to give this a go as my jetting seems to be all over the place. I have a booking on the 13th at Harding Auto's in Woking, Webcon recommended them. If the checks go okay they will dyno it. They seemed to talk some sense to me earlier, but what the hell I will try these jets, Webcon are just up the road from me.
I will report back.
Did that and its soo much better now. 8) Thank you for this post and help
New plugs coming today and I will check timing again.
Capriblu OMG what a difference!
https://youtube.com/shorts/dfvTMwgMbIA?si=IC9VXpw3XlDOrWcJ
Even no choke semi cold silly low tickover if just ran. I owe you a coffee.
It will be interesting what the dyno people do with it now
I think the dyne people will but the air filter lid on and send you on your way. That sounds really sweet!
;D
That is music to my ears Guy, because it = cheaper. :-)
They said that if everything else is good (after a check) they would run a full power test. Maybe I should 'open a book' and take bets on my cars max power output? Anything North of 100 will be a start ;-)
Latest jetting from Harding dyno work
If you are running the latest, I would check the plug colour after a 50 mile motorway drive, as it could be too lean??
Based on? This was after a few runs on a dyno and monitored AFR. I will of course being checking plugs
Always worried when main jet is lower than OEM. You need to run rich at high rpm as fuel cools the engine just saying...
Tim
Wow Mark - she's positively purring in that Youtube clip! I am preparing to have the same done to my Berlina which is running far too rich.
This was on the one but last runs with the their recommended jetting
AFR of 12 or below from 4k rpm? I'm not expert but that looks low. When I had mine set up on a rolling road they targeted 13 or a little above at full throttle.
I will take it on a run and see what the plugs look like. Something I am wondering, the fuel inlet leak also equals air, could this be messing this up? I will try to research, but thanks for the comments
So reminding myself what rich and lean are in the numbers. Mike from Harding Auto's said he wanted to be on the rich side of safe. Not that I have a clue.
https://youtu.be/3sh19RSa8vE?si=GqiHz7vTaJdPuwP5
10 being rich limit and 17 being lean limit.
I want a AFR gauge now :-)
The fuel level with the float dictates the carb fuel supply, so a weeping inlet should have not bearing on it especially given that there is positive pressure of fuel, ie fuel will come out and I would think no air gets in.
Hi Mark 2 things to add to the pile. Betas pre IE VX ran the fuel pipe over the exhaust pipe and did not use an insulator block between the carb and manifold. This leads to hot running/ hot starting issues particularly with modern fuels that evaporate far more easily. It is easy and sensible to put some heat shielding on the pipe crossing the exhaust just behind the subframe. You can get the insulator blocks on the the internet, but do check bonnet clearance.
I have tried tuning by plug colour AKA plug cut tuning with twin DCOE conversions and it is hopeless compared to a Dyno session. I also ran AFR gauges at various times and can view one on the Monte if I wish. More comfort blanket than useful. My Monte ECU does tune from AFR actively at lower load/ RPM as most modern cars do as well. Log files can show me AFR tracks over time. But I do not have the skill or the dyno to re-map.
You can test for air leaks with the engine running by spraying WD40 at manifold joins. A change of engine note will tell you where the leak is. You might need the rolling road to have another look, but sort out the hot fuel thing before going back.
I will check. Thanks Eric. I have no starting issues or obvious hot fuel running problems but will bear in mind.
Hopefully sorted the cam oil leak and can start driving it. Thank you all
Back to this. Low down its not right. I yesterday went out for a longer run into the Surrey Hills. Once moving its good, it low down it just doesnt feel easy to drive. Not any other way I can explain this. I drove it sprited but not much over 4k rpm.
All plugs look like this. Too lean then? So maybe I will go back to the jets Capriblu suggested and see what that looks like?
So you might ask 'why not take it back to the garage, well its a bit of a hike, and I just cant be arsed. I could give you a list of issues I have with the place. I am not sure I can afford to send it there again and be disappointed...
Yes that looks lean. Not the chocolate brown you want to see.
thanks for replying Eric. You all help me not feel helpless :-)
new old jets fitted after I bought them again (sigh). Straight away it runs better. Played with the idle mixture. Out for a spin tomorrow evening.
Seems you lot know more than a garage with a dyno and a AFR systems and a lot of my money!
Car runs really well and even on a short blast the plug colour is getting more like it, thanks again all and especially Capriblu :-)
before and after
It makes me wonder if Hardings put the apprentice on the job un supervised. This is something I experienced at Emerald once leading to a hopeless ECU map with potentially terminal timing. It is so hard to find competent Carb tuning Dynos now and ECU tuners need to have plenty of experience alongside good kit. Beware 2X 30 somethings who setup last week or people who do not care about your car. Perhaps Northampton Motorsport or Aldon Automotive for trusted work based on decades of reputation. It does look like you are very close to having this finally sorted.
Here we go after a trouble free 120 mile to and from Goodwood. My sons had a driving lesson and there was a Alfa track day bonus going on
I drove down the A3 at 3000 rpm ish, and back roads had some fun on the way home. I managed to shut my normally talkative son up with a couple blasts through the rev's and gears. So what do you make of the plug colour on Champion N7Y's on the jetting recommended by Capriblu here
no2 (with the car in the background) and no4
Bit of soot on the bottom of the plug but those electrodes look pretty healthy to me!
Drive it harder? ;-)
So just a follow up regarding my expirementation with jetting - Having been able to get hold of previously unavailable sizes of jets I have finally settled on the following, which seems to provide smooth stumble free response, good econopmy and healthy looking plugs
Primary idle 0.7 (I did try a 0.65 but just not quite right) (standard 0.5)
Secondary idle 0.9 (was on a 1.0 but having got hold of 0.9 this in combination with the above works well) (standard 0.8)
Primary main 130 (unchanged from previous) with 165 air correction jet (was on a 160) (standard 120 main/170 air corrector)
Secondary main 155 (unchanged from previous) with 230 air correction jet (was on a 225) (standard 140 main / 240 air corrector)
One other thing that I have checked and adjusted was the opening/gap of the secondary throttle plate at closed throttle position. There was literally no gap (between throttle plate and body) so I adjusted this using the screw on the base of the carb to provide just over 002" gap. Conflicting guidance on this "online" but general consensus that a very small gap (i.e. not enough to disrupt idle mixture/running) just helps towards minimisation of any momentary "fluff" as second throttle is opened.
Hoepfully with the above settings and good quality E5 fuel car will continue to run smoothly.
Interesting. I will give this a go.
Your previous setting on my car ran lovely, no issues but was smelly, it smelt rich. Even the 70 year old MOT man made a comment. I was trying to understand what each jet does, so is this slightly leaner in places?
Re: opening/gap of the secondary throttle plate, I did try this on jet std jet setting and I quickly reversed. I will try again.
Thanks as always to someone with more brain and time :-)
The primary idle jet may have some influence on idle mixture but this should largely be offset by the necessary coorect idjustment of the idle mixture screw. I would look at the following first ...
Float level - make sure not too high
Idle mixture screw - ensure correct adjustment. (close screw to point where tickover just starts to fall then screw back open slowly to a point just beyond position where tickover rises no further)
Secondary choke throttle plate. If this is set to give a gap between plate and body at closed throttle position then this MUST be very small, no more than 002"/003" otherwise will interfere with idle setting making correct adjustment of idle impossible with rich rough running.
I checked CO at idle after first combination of larger jets and with a smooth tickover was able to get consistently just below 3%
First up just to say thanks to capriblu for posting these results. I will fill in my progress on my thread for the Spider, but just wanted to add that I have found an AFR sensor and gauge invaluable for checking things. The main addition is to add a bung in the exhaust after the downpipe to accommodate the sensor and then route the cables.
