General Category => New members => Topic started by: Eddie Bunn on July 13, 2025, 09:40:48 AM
Title: Lancia beta spider
Post by: Eddie Bunn on July 13, 2025, 09:40:48 AM
Hi,
Firstly thanks for allowing me into youre group.
I have a 1982 spider, the Haynes manual only goes to 1980, it shows 11 fuses in the fuse box, where as my spider has 16 fuses in the box. Is there an updated wiring diagram for the later model?
I curently have no feed to the coil, instrument panel and only part of the fuse box, I notice my 16 fuse box is supplied by 4 multi plugs as aposed to 3 in the Haynes manual.
Is the fuse box fed by 2 heavier bkack and white wires?.
Thanks in anticipation for any help.
Title: Re: Lancia beta spider
Post by: peteracs on July 13, 2025, 10:02:21 AM
Hi Eddie
You should find the links on this thread more useful than Haynes. Haynes is only for pre facelift (up to around 77). Facelift were completely different, especially Fusebox etc.
http://lanciabeta.co.uk/forum/index.php?topic=4239.msg39108#msg39108
Post by: Eddie Bunn on July 15, 2025, 12:20:58 PM
Hi,
Thank you very much for the pdf.
I will now see if I have the were for all to follow it.
Again, many thanks
Ed
Post by: Eddie Bunn on July 16, 2025, 07:20:24 PM
Making progress with wiring,what i thinkis a easier question is ,what are the prefered spark plugs for the 2 ltrtwin cam engine,standard set up?, i shall endeavour to put a face to my name,as requested by admin,as  an 82yr  + 51 week old guy i,m not the sharpest knife in the draw when it come to IT,
Post by: peteracs on July 16, 2025, 10:06:27 PM
Normal for carb engine is NGK BCP6ES, or you can go for the colder NGK BCP7ES. There are resistor versions of these eg BCPR6ES etc.
Post by: HFStuart on July 17, 2025, 10:32:42 AM
We want to see the car not you  :D
Post by: Eddie Bunn on July 20, 2025, 05:35:57 PM
oK the car it will be,have to strongarm the better half into achieving this ,.
