Technical stuff => Ignition => Topic started by: lancialulu on July 23, 2025, 04:38:25 PM
Title: Magneti Marelli Ignition Module for VX part number
Post by: lancialulu on July 23, 2025, 04:38:25 PM
Anyone know the above MM part number (also Lancia PN if available) and if a Hella module of the type (or similar)
https://www.buycarparts.co.uk/hella/936720?tb_prm=Shopping%2FPKW%2FUK_350591613&bshp=1&msclkid=d76214b559f711d56ee37c345867cf1f&utm_source=bing&utm_medium=cpc&utm_campaign=Shopping%2FPKW%2FUK&utm_term=4588605628821619&utm_content=Ad%20group%20%231
......are a direct replacment?
Title: Re: Magneti Marelli Ignition Module for VX part number
Post by: Ics19 on July 23, 2025, 06:45:31 PM
I'd stay clear of the Hella units as it seems they've changed how they work a couple of years back - this has caused endless grief as it's been proven the ignition retards as revs increase!  There's a whole Ferrari-chat thread on the Hella module demise and folk who've tested them.  Even new Marelli ones been unreliable as they're now just re-brands (mako?). I think the conclusion was the Pertronix D2000 is the next best (but pricey) alternative.  I've used an intermotor 15210, but can't say the spark is as good as an original GM module, a Pertronix beckons...
Pretty sure you're looking at 82369531 for the Lancia code.
Post by: lancialulu on July 23, 2025, 09:55:25 PM
Thanks for this info.
I thought the advance was provided by the distributor and the Marelli module was just a switching amplifier for the coil???
Anyone???
Post by: Ics19 on July 23, 2025, 10:54:25 PM
Yes, that's right, the module shouldn't enter into it - but what appears to happen with the later hellas is the switch off / de-energise point doesn't stay in line with the input and progressively delays as the rpm increases, hence gives the weird effect of retarding the ignition.  The hella module looks to have been the go-to replacement as it had decent current handling.
Post by: lancialulu on July 24, 2025, 12:30:08 PM
All fine now.
