Technical stuff => Electrical => Topic started by: garethwd on February 21, 2026, 08:30:08 AM
To change the repeater indicator build .. Do I need to remove the arch liner? Or does the flasher pull off?
Not silly at all....
The original fixing is via two small nuts on the inside of the wing, so yes you need to pull back the liner to locate them. The bolts/nuts are often rusted and care need to be taken removing the nuts or the whole thing will just revolve in the plastic.
Sounds like a great deal of fun🤣... Ok thanks, I didn't want to start pulling on something that shouldn't be pulled off. I will give it a go.. Thank you
To change the bulb its a pull out from the back of the unit
see
https://www.ebay.co.uk/itm/406032731550?var=0&gclsrc=aw.ds&&mkcid=1&mkrid=710-53481-19255-0&siteid=3&campid=5338980692&customid=jkp_CjwKCAiAzOXMBhASEiwAe14SaZSjawclALbqKDqe7AnBlnY-Jv91kAylyAO2fkII_JMHFoB3pdQE4hoCcgQQAvD_BwE&toolid=10001&mkevt=1&gad_source=1&gad_campaignid=20130282845&gbraid=0AAAAAC9EKSfcE-uhcxJXud_nWZnSvrOf_&gclid=CjwKCAiAzOXMBhASEiwAe14SaZSjawclALbqKDqe7AnBlnY-Jv91kAylyAO2fkII_JMHFoB3pdQE4hoCcgQQAvD_BwE
look at that, how to do it and an incentive not to break the current one in one post 8)
Wasn't needed in the end. I've been cleaning earths and connecters and hey presto. 🥳
