Technical stuff => Electrical => Topic started by: hongkongphooey on November 17, 2010, 07:27:48 PM
Title: Handbrake warning light
Post by: hongkongphooey on November 17, 2010, 07:27:48 PM
Is it supposed to flash through the indicator relay?
Title: Re: Handbrake warning light
Post by: MattNoVAT on November 17, 2010, 07:32:39 PM
Hi,
Yes it should - although when mine failed I had to use a Delta indicator relay so it no longer flashes!
Post by: thecolonel on November 17, 2010, 07:56:41 PM
Up under/ to the right of the the steering column there should be a two pin flasher unit,
small silver/alloy can (just over 1 inch diameter).
This is the handbrake flasher unit (does not normally use the standard indicator or Haz unit)
the unit runs at about 2w , anything greater and there would not be enough draw to flash the lamp.
Geoff
Post by: hongkongphooey on November 17, 2010, 08:42:43 PM
God,it's so annoying! What with that and the 50 switch positions for the headlamps! ::)
Post by: WestonE on November 26, 2010, 06:18:51 PM
Hong Kong
I re-wired mine without the flasher so it just lit the light as it drove me mad as well!
Post by: cheeky monkey on November 26, 2010, 09:13:40 PM
disconnected my hazard warning light.  the indicators have been better since
Post by: hongkongphooey on November 27, 2010, 03:51:51 PM
I'm glad i'm not the only one it annoys! Might have to by-pass it then....My indicators aren't the best either so hopefully it'll help them too!
Post by: cheeky monkey on November 27, 2010, 05:57:42 PM
by the way, i meant the handbrake warning light not the hazard. You soon get used to not hearing or seeing the warning light flashing.
