Author Topic: Oil Pumps  (Read 7053 times)
Oil Pumps
« on: September 16, 2012, 09:55:01 AM »
Early 1300, 1400, 1600 & 1800- 82317492
Early 2000 - 82334025
Can anyone complete this with the ie and VX ?
« Last Edit: September 16, 2012, 09:59:47 AM by HFStuart »
Re: Re: Oil Pumps
« Reply #1 on: September 16, 2012, 02:47:29 PM »
Will have a look when I can microfiche is disconnected at the moment as I am moving it into the house do that I can check things more easily but I need to put a shelf up for it
Offline monte
Re: Oil Pumps
« Reply #2 on: September 16, 2012, 03:12:37 PM »
Had a look at the microfis ,  VX is 7032541
But no pump listed for the ie ,Maybe ie uses the standard 2000 pump ??
Odly the microfis has another pump listed as 82377590 but no engine size or type linked to it ??
1984 Beta Coupe VX
1985 Beta Coupe IE
1980 Montecarlo Spyder
1989 Integrale HF 16V
1989 Thema 2000IE
1991 Thema 2000IE
Re: Oil Pumps
« Reply #3 on: September 16, 2012, 03:30:54 PM »
Thanks for that, very interesting.
Well this listing is for than part number and it looks very much like a VX Pump too - so perhaps that was just a later version?
http://www.ebay.co.uk/itm/370412512273?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Re: Oil Pumps
« Reply #4 on: September 16, 2012, 05:08:01 PM »
Re: Oil Pumps
« Reply #5 on: September 16, 2012, 05:13:23 PM »
82377590 is a later modification the annotation C7254/D7254 refers. I can't use my fiche reader at the moment so I can't look the alteration '7254' up although tbh the description may not be particularly descriptive! It would appear that one pump replaced all 1.3/1.6 and 2.0 derivatives (but not VX) they did rationalise parts on other items as well such as the clutch release bearing so it's not surprising. Is it just me or does that pump on ebay look painted? I have a vx pump off the car at the moment if I find time I'll take a picture for comparison.
« Last Edit: September 17, 2012, 03:15:49 PM by rossocorsa »
Re: Oil Pumps
« Reply #6 on: September 20, 2012, 12:04:14 PM »
Re: Oil Pumps
« Reply #7 on: October 27, 2012, 03:33:52 PM »
7254 states 'nouva pompa olio e coppa per basamento' new pump and sump
2000 346304
1600 388287
1366 388306
I checked and it seems they changed the sump spec on 1.3 and 1.6 to the same as 2.0 at the same time as introducing the new pump design
