Hi All
It has been so many years since I worked for a Lancia dealer that the brain cannot recall the following so I wonder if someone can help.
The cam belt on my 2.0l Spyder seems to be out of line and running over the edge of the cam wheels, it has damaged the inlet wheel guide lip. However, I have noticed that the inlet wheel is of a fibre material and so is the auxiliary shaft wheel but the exhaust cam wheel is metal. Should the metal wheel be on the auxiliary shaft or has someone replaced something with a non standard part?
Tim
