Author Topic: Accelerator pedal movement  (Read 4039 times)
« on: February 03, 2013, 02:07:48 PM »
This may be a daft one, but see photos- the pedal floats sideways.
Not urgent, as she is not on the road, but I noticed it yesterday while starting her up.
Note cool carpet offcut mats too - again contemporary with the car.
Any ideas?
Re: Accelerator pedal movement
« Reply #1 on: February 03, 2013, 08:18:28 PM »
This happened to me.
The nylon block the pedal hinges in is securred to the bulkead by an M6 nut on a stud and a locating pin that stick out of the back of the block.
Your pin has sheared off. About the only safe fix is a replacement block though you may get away with araldite or similar for a while.
They do come up on eBay every so often. Or you could get one machined up in aluminium.
Edit  - Found a picture
http://www.ebay.com/itm/lancia-beta-throttle-pedal-bracket-/250988985876?ViewItem=&item=250988985876&nma=true&si=2JzH5Y8k4hsUDwV4BhinNPjv3pg%253D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
That one was sold by Chris Bastow ex of Betacar in Bradford - it might me worth asking him if he's got another.
« Last Edit: February 03, 2013, 08:22:35 PM by HFStuart »
Offline archigraphe
« Reply #2 on: February 03, 2013, 10:16:00 PM »
Be aware, this part is different between the first and later series...
« Reply #3 on: February 04, 2013, 02:02:28 PM »
Thats fantastic - thanks.
Looking up I can see the white plastic hinge sliding about so can get onto that- another one for the list!
