Author Topic: rubber boot  (Read 3078 times)
Offline raz1966
rubber boot
« on: May 17, 2013, 05:50:40 PM »
how much of a job is it to fit a new rubber boot on the passenger side, the one which goes over the cv joint, near the brake disc
Re: rubber boot
« Reply #1 on: May 17, 2013, 11:02:12 PM »
It's quite a job but if you have the right tools its easier. Or you could cheat and use the cv boots that you fit over and the superglue up the side!
Re: rubber boot
« Reply #2 on: May 18, 2013, 09:17:59 AM »
Haven't tried a superglue boot on a Beta but the one I did on my old 205 only lasted two weeks.
Re: rubber boot
« Reply #3 on: May 18, 2013, 11:01:21 AM »
I used one on my old Renault Espace - worked a treat, was still hanging in there after a year and 9k+ miles
