It seems like the more I drive my '77 HPE, I'm noticing along with pulling to the right, it has a front end shimmy above 25-30 mph. I have replaced the lower wishbone bushings, sway bar bushings, repacked the CV joints with new boots and new tires. While I had the lower wishbones loose to replace the bushings, I checked the lower ball joints for play and they didnt have any and seemed fine. The problem existed before the parts previously mentioned were replaced. I also checked the tie rod ends for play also. I had suspended the front end on jackstands and run the car up, also checking for bearing noises (there are none now) and couldnt replicate the shimmy thinking it was rims or tires. As I previously posted about a right front end noise, it turned out to be road noise from the tires up front, which may signify a problem somewhere in the front end. Is there any other part to the front end that I may be over looking, like the upper strut mountings, that may be suspect?
Thanks,
Mike
