Author Topic: Hose location  (Read 3637 times)
Offline Spyderfan
Hose location
« on: August 22, 2017, 06:04:00 PM »
Hi , I've tried asking on the cooling thread but to no avail so will try on here in the hope someone can help ..
Near the water pump behind the block are two pipes next to each other coming out ..left hand one goes to carb , where does the right hand one end up? It's around twice the width of the other one and is longest pipe in engine . Guessing a heater hose of sorts ...
Please help !!
Offline jreacock
Re: Hose location
« Reply #1 on: August 22, 2017, 08:50:01 PM »
Hi. Yes - If I remember, it goes to the shorter of the two heater hoses coming through the bulkhead. You almost have to attach and detach it as the engine is going in or out, as it's quite hard to get to when the engine is in place. It may be easier if you have ramps though I guess.
69 Fulvia 1.6HF S1
71 Works Fulvia 1.6HF
75 Gp4 Stratos HF
81 Beta Spyder 2.0
82 037 Rally stradale
Offline Spyderfan
Re: Hose location
« Reply #2 on: August 22, 2017, 11:11:16 PM »
Hi many thanks for your reply . I have a slightly different set up but the two outlets are the same as on mine . My question is , where does the other end go from the wider of the two outlets ?
Wish I could post pic on here but it's not letting me ..
Re: Hose location
« Reply #3 on: August 23, 2017, 12:07:15 AM »
Through the bulkhead to the heater control valve
