Author Topic: 1981 coupe injection..30 years since last started  (Read 4530 times)
Offline smudge2031
« on: September 03, 2018, 08:00:02 PM »
So, Im trying to revive this 1981 Beta coupe injection. I am not getting any spark and injectors are firing......cleaned most contacts etc......Im presuming the crank sensor triggers the ecu to spark and pulse the injectors??
Re: 1981 coupe injection..30 years since last started
« Reply #1 on: September 04, 2018, 06:54:51 AM »
Is the airflow meter and throttle potentiometer working?
Offline smudge2031
« Reply #2 on: September 07, 2018, 07:39:10 PM »
hi yes seem to be.......what does the flywheel sensor do? rev counter?
« Reply #3 on: September 08, 2018, 10:42:43 AM »
Timing for the injection most likely. Isn't the ignition still via the distributor?
Offline LanciaDave
« Reply #4 on: December 26, 2018, 07:49:16 AM »
Where do you lose spark? Is it to the plugs, wires, dizzy cap, coil, etc?
Dual relay is a common one to go bad on the late FI cars, but could be other suspects...
Dave
Wilds of the Pacific NW, USA
77 HPE 1.8L manual steering
77 Sedan 2L FI
84 HPE Vx
