Author Topic: Height adjustable suspension  (Read 6288 times)
« on: October 16, 2009, 09:25:29 PM »
Has anyone thought or enquired about adjustable spring seats for Beta suspension?
I've tried to sort something (anything) for one of my Gamma and no-one seems
interested.
There are comparisons to be drawn between the Gamma and Beta set-up, similar
struts etc so I'd be quite prepared to fit modified Beta suspension on the Gamma
if I can find a source.
Geoff
Re: Height adjustable suspension
« Reply #1 on: October 17, 2009, 10:51:07 AM »
http://www.leda.com/pdf/product_list.pdf may well be what you are looking for ???? but expensive
« Reply #2 on: October 19, 2009, 10:45:00 AM »
Thanks, I'll try them again, EPM the company that took over most of the Leda work
didn't seem interested.
Geoff
« Reply #3 on: October 19, 2009, 08:43:59 PM »
Geoff
I just looked that up on the 'net so every chance that they'll still not be interested, why do you want height adjustable platforms by the way?
« Reply #4 on: October 19, 2009, 09:44:26 PM »
I like to lower the car a bit and also change to 2.5 id  uprated springs
( 6 kg front 4 kg rear) give it more of a chance on the track.
It's more of a cruising continental GT at the moment and I really don't
want to start the planned power increases until I can sort the handling
and braking, it stops fine for a coupe but not good enough for serious
mis-use.
Geoff
