Author Topic: Steering wheel adaptor query  (Read 10196 times)
« on: August 26, 2020, 10:47:44 PM »
I've got a replacement steering wheel for my car, but it needs a hub.
I need to know whether the spline at the top of the column is the same as *which car?* or
what I should be looking for.
Beta's generally not listed as options in lists!
Nige
Offline betabuoy
  • Chris Mace
Re: Steering wheel adaptor query
« Reply #1 on: August 27, 2020, 08:12:54 AM »
Morning Nige
Try Ricambio https://www.ricambio.co.uk. They supplied my adapter and list it for the Beta.
Chris
1967 Morris Minor Traveller
1925 Austin 7 Chummy
« Reply #2 on: August 29, 2020, 08:57:33 PM »
Thanks Chris.
The beta version shows out of stock but i'll
call him next week to ask if any other will fit.
He has a huge range!
Cheers, Nige
Offline flex
« Reply #3 on: September 01, 2020, 10:33:36 AM »
My understanding is that there are two different splines used on the Beta. The later ones (Probably Series 3) is shared with late Gammas and Deltas to ~1984. I don't know about earlier cars.
for example (out of stock):
https://www.ebay.co.uk/itm/LANCIA-Delta-up-to-09-1984-Gamma-77-SAAB-600-Steering-Wheel-Hub-Boss-LUISI/322891963141?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
So many cars, so little time.
Offline esteemz
« Reply #4 on: September 01, 2020, 11:55:31 AM »
Try Luisi s3805 or contact Springalex ltd
« Reply #5 on: September 01, 2020, 05:44:14 PM »
Omicron usually have some. But not cheap of course.
PS you can easily get Nardi/personell to Momo adaptor spacers from ebay.
« Reply #6 on: September 01, 2020, 08:01:51 PM »
Thanks all.
I'm going to take the steering wheel off and compare the spline with
another column i've got. I know the spare column is before 82 so
I should see the difference,if any.
Nige
« Reply #7 on: September 02, 2020, 07:25:10 PM »
Interesting, there's no difference between a pre 82 and 84 splines.
And I really think the spare column is older than that.
The wheel only fits in one position, normal.
To be continued......
