Author Topic: Should the clock in a pre facelift Coupe light up?  (Read 2746 times)
Offline GerardJPC
« on: January 19, 2021, 07:46:19 AM »
Dumb question alert!  1978-79 car with pre facelift interior.  The clock located in the wooden panel with all the knobs on it works but does not light up.  Is it supposed to?  If so, I foresee swearing ahead as I try to access the bulb.
1973 Lancia 2000 HF Coupe
1982 Moto Guzzi V50 Monza
1982 Moto Guzzi V35 Imola
1983 Land Rover Series 3 88
2009 Jaguar XK Coupe 5.0
Re: Should the clock in a pre facelift Coupe light up?
« Reply #1 on: January 19, 2021, 08:25:14 AM »
The pre-facelift saloon clock that I have in my stash has a bulb holder, so presume the same for the Coupe? Isn't the wood effect panel holding the clock just held in by 4 thumb type screws? Much easier to get at than the facelift clock!
« Reply #2 on: January 19, 2021, 08:54:34 AM »
Hi Gerard
Yes, it should be linked to the side light circuit as per other lamps on the centre section. It is a simple pull out holder and the lamp is a small baynet type bulb. Access should be possible via the speaker grill on top of the dash rather than trying to get at it from the centre section.
Offline GerardJPC
« Reply #3 on: January 19, 2021, 04:58:01 PM »
Cool, thanks all!
