Author Topic: How to replace door quarterlight glass ?  (Read 40 times)
Offline JASPER_40
  • Country: au
« on: April 19, 2026, 11:17:39 AM »
Hi Everyone,
It has always annoyed me not having a passenger side door mirror and I am now in possession of a door mirror and corresponding glass and am wondering how difficult it is to replace the quarterlight glass. I have currently removed the door card and there are no obvious screws for the horizontal channel within the door. so before I get too far into dismantling the door, I thought I would ask.
Any hints or tips would be much appreciated.
Steve
Current project in Aus :
Previously owned in UK:
1984 HPE Volumex
1982 HPE 2000 IE
1979 Coupe 1600
Re: How to replace door quarterlight glass ?
« Reply #1 on: April 19, 2026, 12:11:54 PM »
Hi Steve, if you've got the door card off you're almost there!
First disconnect the drop glass from the winder mechanism, two bolts can be accessed through holes in the top of the inside of the door, and drop the glass (carefully) into the bottom of the door.
Then undo the two bolts/screws holding the front window channel in place and remove (you may need to ease the window felt out of the channel if it's one piece to the top).
Next, there's a single stainless screw on top of the door frame through a nylon bush, unscrew this and this should allow you to pull the channel back. the rubber quarter light seal should pop out. Then just pull the quarter light backwards and it, with its rubber seal, should come out easily.
Underneath the window seal is a rubber strip that may be glued down. Remove this and check the top of the door for corrosion and treat anything you see. I'd also recommend a liberal application of Waxoyl or similar into the top of the door underneath this aperture and above the interior door opening handles as rot is very common there.
Reassembly is just the reverse sequence.
Offline JASPER_40
  • Country: au
« Reply #2 on: April 19, 2026, 12:54:50 PM »
Many thanks Guy…..will get to it straight away and report back
Steve
1984 HPE Volumex
1982 HPE 2000 IE
1979 Coupe 1600
