Author Topic: Brake pipe alignment pins  (Read 2459 times)
« on: August 03, 2022, 09:45:14 PM »
Does anyone know of a source for these?
They look to be 3mm dia with a full length ‘slot’ although its quite hard to be sure judging from the remains. None of.mine are really good enough to re use.
Thanks in anticipation.
Re: Brake pipe alignment pins
« Reply #1 on: August 03, 2022, 10:19:54 PM »
Hi Mark
I bought some similar split spring type pins on Ebay for the yoke to callipers when I reassembled them. My replacement brake hoses did not have the locating holes, so simply cut the ones off the callipers.
Sorry no idea on size at this point.
« Reply #2 on: August 03, 2022, 10:22:27 PM »
Good day,
They are a standard 'roll pin'.
I'd measure the size and order through ebay. Use the caliper hole to measure with a drill bit.
They only ensure orientation of the hose i.e. prevent rotation.
You should be able
to get the correct length, although a little shorter won't do
any harm. So long as they protrude plus minus 4mm from the caliper
they'll work well.
Regards
« Reply #3 on: August 04, 2022, 09:39:21 AM »
Brilliant - thanks. Amazing how much more easy it is to find things when you know what the things are called!
All measured and ordered.
