Author Topic: Road springs  (Read 13526 times)
Offline TreviDash
Road springs
« on: August 02, 2009, 02:01:03 AM »
Would somebody be able to list the Beta coil spring sizes, model to model,  please?
I have this set
With dimensions: Length 33 cm, Diameter 16 cm.
Thanks.
'84 Alfa 33 Gold Cloverleaf
'92 Daimler Six
Re: Road springs
« Reply #1 on: August 02, 2009, 03:00:02 PM »
they look after market to me
Re: Road springs
« Reply #2 on: August 08, 2009, 04:00:14 PM »
Yep, me too.
Offline TreviDash
Re: Road springs
« Reply #3 on: August 10, 2009, 10:14:56 PM »
Thanks, but umm that wasn't what I asked..... :P
'92 Daimler Six
Re: Road springs
« Reply #4 on: August 11, 2009, 08:40:27 AM »
PM me with your e-mail and I'll send you the tech data book with all the spring lengths (and a shed load more)
Offline TreviDash
Re: Road springs
« Reply #5 on: August 11, 2009, 05:57:44 PM »
Thanks.  My email address is on my profile
'92 Daimler Six
Re: Road springs
« Reply #6 on: August 11, 2009, 06:58:30 PM »
Done
Re: Road springs
« Reply #7 on: August 11, 2009, 07:52:04 PM »
This may or may not work..
Re: Road springs
« Reply #8 on: August 11, 2009, 08:15:47 PM »
Next image in the sequence....
Re: Road springs
« Reply #9 on: August 11, 2009, 08:17:02 PM »
And the final image ....  I'd suggest maybe copy the image and then blow it up a wee bit if you cannot make out the numbers.
Re: Road springs
« Reply #10 on: August 11, 2009, 09:36:39 PM »
Do you have another ? Hotmail bounced both e-mails probably as they're too large.
Offline hongkongphooey
Re: Road springs
« Reply #11 on: January 14, 2010, 07:57:06 AM »
Does anything on there relate to the actual spring compression rates? (sorry for the thread bump,you may get this a lot with me  ;D)
Re: Road springs
« Reply #12 on: January 14, 2010, 09:58:20 AM »
You can work it out from the free length, length under static load and load figures in the first picture.
Stuart
Re: Road springs
« Reply #13 on: January 14, 2010, 06:40:21 PM »
So for the coupe front,i make that compression of 308mm (12.13") which seems a lot. Under 330kg (726lb).
So that's 60lb/in springs for the front. That seems weak,i could compress that by 3" just by standing on it. Or i on the wrong track?
Re: Road springs
« Reply #14 on: January 14, 2010, 09:29:24 PM »
Compression of 208 mm I make it, think that's where you went wrong.
Re: Road springs
« Reply #15 on: January 14, 2010, 09:32:51 PM »
88.8 lb/in
Re: Road springs
« Reply #16 on: January 14, 2010, 09:49:46 PM »
Betaboyz lowering springs, 30mm lower, 25% uprated, must be around 111 lb/in.
« Last Edit: April 11, 2010, 11:12:14 AM by lanciamad »
Re: Road springs
« Reply #17 on: January 14, 2010, 10:01:38 PM »
LOL....Oh yeah! ;D
Still,88 is weaker than i expected. I may go for some home made coilovers actually as the springs on mine are already cut and are still too squishy.
Offline Lancia Beta 2000
Re: Road springs
« Reply #18 on: June 30, 2010, 11:05:41 AM »
Hi Guys,
someone of you, can tell me the inner diameter of coupe springs??
I can't read this value on my tech books..
Thank you very much..
