Would any of you fine people be willing to take me through troubleshooting a "crank, no start" condition on my 1981 Zagato w/ the Bosch FI?
Last year, I pulled the tank, had it cleaned and dipped, replaced the pump, filter, and various hoses. I also yanked the injectors, had them professionally refurbished, and replaced the engine side fuel hoses during re-install.
After all that work, the engine ran well. Idled fine, etc.
The problem was that is felt like driving in an empty paint can, so I set about replacing all the motor mounts, shocks all around, front end bushings, etc.
I also pulled the steering rack and had it professionally rebuilt.
OK, so... I wrestled the rack back in and reconnected over the weekend and thought, "I'd better start this thing, just to test whether the rack has any leaks before I button this all up." Mind you the car had been on stands for about 2 months at this point, but the gas in the tank should be ok.
It now cranks and doesn't start, when it was running and starting just fine when I put it on the stands. I've done the "flap" test on the AFM, and I don't hear the pump running. I also pulled the fuel line off to the rail and cranked-- no fuel comes out. So, fuel pump doesn't seem to be working, but it was new and working fine when it was parked...
Anyone have some suggestions on what I should try next? I have a spare "dual relay" for the FI system that I tried, and I'm getting the same result.
Any thoughts on direction greatly appreciated!
