Author Topic: Electric window cables  (Read 4669 times)
Offline mark
« on: March 07, 2010, 12:41:16 PM »
Hello all, Ive just stripped down the elec window mechanism and need a pair of cables which I will order through the club. Im concerned that the gear that drives the cable is knackered as well. Am I right to worry or are the gears ok once a new cable has been fitted ? The gear is sealed in the housing as Im sure your all aware, so I have no way checking.  Thanks in advance Mark.
markwast
Re: Electric window cables
« Reply #1 on: April 04, 2010, 08:13:15 PM »
Hi Mark
As  far as i can remember the gear is very tough. the manual ones are metal.
Hope that helps
Mark W
