Author Topic: electric window switch illumination  (Read 5959 times)
Offline spud
« on: February 22, 2011, 10:43:09 AM »
Hi all,
Does anyone know the type of bulb that is fitted in the electric window switches on the HPE VX?
They're not the same as the dashboard bulbs- I know they are called 'T5'. I'm hoping to replace all the interior light bulbs with leds and these switches (long with the rear wiper switch incidentally) are a different bulb design.
Andrew.
Montecarlo S2 Spyder
HPE VX
Y10 GTi.e. x2
Re: electric window switch illumination
« Reply #1 on: February 22, 2011, 05:01:41 PM »
I thought these were illuminated vis the fibre optic cables.  Similar to the lights above the ashtray.
There is a bulb that supplies the light into one end of the fibre optic and the light is carried down to the switch and there's a small plastic end on the cable that spreads the illumination behind the switch.
Offline spud
« Reply #2 on: February 22, 2011, 05:03:43 PM »
There is a fibre optic system on my Monte- I am familiar with that system. No, this is an actual bulb. All the interior switches on my HPE have bulbs.
Andrew.
HPE VX
Y10 GTi.e. x2
« Reply #3 on: February 22, 2011, 05:08:03 PM »
And people say that German cars are over engineered!!
Offline spud
« Reply #4 on: February 22, 2011, 06:01:27 PM »
Here's a couple of pics of the bulb with the switch body in the background.
HPE VX
Y10 GTi.e. x2
« Reply #5 on: February 22, 2011, 07:04:58 PM »
Maplins keep a similar bulb (slightly smaller)
I've replaced them in the past, you need a steady
hand with the soldering iron.
Offline spud
« Reply #6 on: February 22, 2011, 08:35:08 PM »
Thanks Geoff I'll have a look. I'm good at soldering so no problems there.
Andrew.
HPE VX
Y10 GTi.e. x2
