Todd,
Sorry forgot about rear setup. All is standard at present, std specs are toe in 2-5 mm, 1 degree negative camber. My transverse links are adjustable tubular early type (my car is 1975 model), later models used different pressed type non adjustable links, with offset bottom bolt to adjust toe.
My car uses betaboyz lowered springs, poly bushes and spax adjustable shocks all round, and have no complaints about shocks, although springs need to be stiffer for circuits, good for hillclimbs with slower turns and more bumps. Even at 125 mph shocks still good !!! Coilover setup needed for adjustability and to lower the car more.
I am planning using some camber plates/adjustable top mounts in the future, as I want to get rid of the rubber top mount on the strut. I believe Ford Escort and Mazda RX-7 gen2 ones can be made to fit easily - see other posts in this section "adjustable top mounts"
I have found traction out of corners can be a problem - inside wheel spins, I am planning an LSD in the future.
Can you post some pics of your coilover setup? Would be very interested in what components are used.
Regards
