Author Topic: Brake Pipe Fittings  (Read 4860 times)
Brake Pipe Fittings
« on: June 29, 2011, 06:57:11 PM »
Anyone know what shape fittings to use for where the solid lines fit to the flexible lines? A photo/drawing would be great. I assume they have a tapered end as I have some flat ended ones and they don't fit. I'd like to get some before I start dimantling.
Re: Brake Pipe Fittings
« Reply #1 on: June 30, 2011, 11:43:24 AM »
Hi Neil,
I presume your renewing the metal brake pipes between the rear brake bias to the inner arch where they meet and change to the flexible rubber hose?
If you can hold on till this weekend I'll be looking in detail at mine and will start my investigations and get back to you.
I plan to remake all metal pipes (with either copper or cupro-nickle) and replace the existing ones, although still intact I'd rather replace with new copper pipes.
Anyone know which is better to use Copper or Cupro-nickle?  (I have both already)
« Reply #2 on: June 30, 2011, 12:01:31 PM »
Matt, yes the union between the metal pipe from the bias to the flex pipe is what I'm referring to.
« Reply #3 on: July 06, 2013, 10:01:52 PM »
Just need to bump this one. Any ideas on the size/shape of the brake pipe unions/fittings (10mm by 1mm pitch??).
« Last Edit: July 06, 2013, 10:10:21 PM by Neil-yaj396 »
