A slight change of plan in the last couple of weeks.
The engine is going together, progress is slow but I'll get there.
Of more interest is that I asked my dad to machine the rear of the pulley I got from Millers Mule to give a touch more clearance. This he did and left it in my garage next to a box that turned out to contain a pair of Solex 40 ADDHE Carbs! Apparently they'd belonged to the father of one of his colleauges, he passed away and the colleague had no use for them. Bit of a bonus really!
They need overhaul but even so.....
I was thinking that if I'm going to buy a pair of Webers I might as well go for injection. A free pair of carbs though changes this. So I'm going to use them for a Megajolt controlling the ignition.
In the meantime I've been shimming up the cams and found that there was no clearance on two of the valves, the seats have obviously dropped back a bit when the head was ported. I'd have had to go too thin of the shims to get the right clearance and that was worrying me a little unitl I found there are two thicknesses of cambox gasket roughly 0.9mm and 1.4mm. If I fit the 1.4mm hey presto clearance again.
Next step final assembly of the head and timing.
Stuart
