Author Topic: vacuum leak  (Read 12497 times)
Offline sainthaloblue
vacuum leak
« on: January 21, 2012, 03:48:56 PM »
Hello everybody! i have a vacuum leak on my 79 beta 2.0 engine I just bought the car and have vacuum leaks and vacuum lines that go nowere just pluged off does anybody have a vacuum or emission diagram?
« Last Edit: January 21, 2012, 03:50:33 PM by sainthaloblue »
Re: vacuum leak
« Reply #1 on: January 21, 2012, 04:11:01 PM »
Can you take a picture of the pipes that go nowhere?
It will help identify and likely speed up the process of determining where the pipe should go.
rossocorsa
Re: vacuum leak
« Reply #2 on: January 21, 2012, 09:37:31 PM »
I can e mail you the original pictures if you find these too small North American models are very complicated and I'm afraid i know next to nothing about them
« Last Edit: January 21, 2012, 09:39:37 PM by rossocorsa »
Re: vacuum leak
« Reply #3 on: January 22, 2012, 03:27:12 PM »
I am out of town but will take a picture and post it as soon as i can
Re: vacuum leak
« Reply #4 on: January 22, 2012, 03:30:17 PM »
Thank You for the pics and im sure u know alot more than seeing as this is my first Beta and carbureted engine! and I would appreciate it if u would email me the pics my email is sainthaloblue@yahoo.com
Re: vacuum leak
« Reply #5 on: February 05, 2012, 04:37:14 PM »
Here are dome pics I kno they aren't that good but i hope it help.
Re: Vacuum leak
« Reply #6 on: February 05, 2012, 05:00:51 PM »
The pipe in the top picture that is marked "Vacuum line" this is blanked off on my normally aspirated 2.0 with a  34 DATR.  On my car there is a very small brass T section that comes off the inlet manifold.
Re: The top picture... Is your brake servo connected??
In the lower picture the larger bore connection with no pipe on it I think should be the crank breather and that used to have a pipe running up to the underside of the stock air filter housing.
« Last Edit: February 05, 2012, 05:19:49 PM by MattNoVAT »
Re: vacuum leak
« Reply #7 on: February 05, 2012, 06:50:38 PM »
Matt,
I think the pipe in the top picture that he says has pressure could well be the crank breather hose. Unless you got had a really good look in you might well think that comes from the inlet.
Stuart
Re: vacuum leak
« Reply #8 on: February 05, 2012, 07:45:05 PM »
It does look like the crank breather just by the shape of the pipe and the marks from the hose clip, it looks like its the right routing to fit onto the underside of the air filter housing.
The pipe-less connections are throwing me a bit.
We'll get there slowly but surely :~)
Re: vacuum leak
« Reply #9 on: February 05, 2012, 09:05:28 PM »
Looking at where the photo is taken from (past the dizzy) it's not the fuel pump is it?
Offline cheeky monkey
Re: vacuum leak
« Reply #10 on: February 06, 2012, 02:36:34 AM »
it does look like the fuel pump
1979 beta coupe 1300
Re: vacuum leak
« Reply #11 on: February 06, 2012, 07:47:23 AM »
So the question is: has the mechanical fuel pump been replaced with an electric pump?
Offline Thotos
  • Theo Kyriacou
    • Lancia Gamma Consortium
Re: vacuum leak
« Reply #12 on: February 06, 2012, 10:45:54 AM »
Has the car been converted from automatic to manual at some point? The automatic cars have a vacuum valve controlling the idling speed and it could be that some of these lines were not connected when the car was converted?
Top picture, both pipes should connect to the air filter. The bigger pipe is the crankcase breather  and the second pipe is the EGR (exhaust gas recirculation) valve pipe (I think  :-\ ) Has your car been fitted with a K&N (or similar) air filter? A lot of people don't know what to do with these pipes once they change the standard air filter.
The two unconnected pipes on the manifold are meant to connect to water pipes for manifold heating? This is the case with automatic cars but might not be for manuals.
Theo Kyriacou
Offline Thotos
  • Theo Kyriacou
Re: vacuum leak
« Reply #13 on: February 06, 2012, 10:49:41 AM »
On second (and more careful) look, no it isn't! The EGR pipe is shown above it and seems connected (to the carburettor end at least). The small unconnected pipe is just a vacuum pipe which would connect to the idling adjustment valve for an automatic car.
Theo Kyriacou
Re: vacuum leak
« Reply #14 on: February 18, 2012, 04:30:16 PM »
Yes it has a electrical fuel pump I was told by the previous owner. so these cars originally came with mechanical fuel pumps?
Re: vacuum leak
« Reply #15 on: February 18, 2012, 04:33:34 PM »
I dont think think this car was a auto I believe its always been a manual. and the fuel filter has been replaced it has a 34datr its weird because its a auto choke but it also has a manual choke on it.
Re: vacuum leak
« Reply #16 on: February 18, 2012, 04:36:57 PM »
As standard it would have had a mechanical pump just under the inlet manifold.
It's possible that you might have a DATR with a manual choke conversion fitted. There were kits to do this or it could have been done with parts from a DMTR.
rossocorsa
Re: vacuum leak
« Reply #17 on: February 18, 2012, 05:35:23 PM »
maybe maybe not North American spec differed almost every year so from this side of the water it's really difficult to know
