Author Topic: one step forwards...two steps backwards  (Read 4218 times)
Offline raz1966
« on: March 01, 2012, 07:11:48 PM »
i decided to give it an oil change, i drained the oil, changed the filter, no problems ...then when i done up the drain plug it just kept screwing in until it fell into the sump!
so now i got to drop the sump to get the bloody thing out, how hard a job is this?
Re: one step forwards...two steps backwards
« Reply #1 on: March 01, 2012, 07:21:47 PM »
Can be tricky. You need to rasie the engine a bit above the subframe to get the sump off around the oil pump - or drop the subframe out of the way. An engine support beam like this one (  http://www.ebay.co.uk/itm/Sealey-Engine-Support-Beam-500kg-Capacity-Double-Support-ES502-/130636078383?pt=UK_Lifting_Moving_Equipment&hash=item1e6a845d2f )  helps but you can probably impovise.
Offline raz1966
« Reply #2 on: March 01, 2012, 07:38:29 PM »
thanks for that
Offline raz1966
« Reply #3 on: March 02, 2012, 01:24:47 PM »
got the sump off, used a bit of wood across the strut tops and some straps to holt the engine/gearbox. pain in the arse but thats classic cars
« Reply #4 on: March 02, 2012, 05:16:51 PM »
Raz
As you have the sump off take the opportunity to change the bearings one at a time using a good quality torque wrench to do the nuts and bolts back up. As a minimum inspect them one at a time as it is better to know if they are damaged or well worn.
PS the sump plug should be a tapered item that cannot fall into the sump so something is very wrong there either plug or badly damaged threads
Offline raz1966
« Reply #5 on: March 02, 2012, 05:54:31 PM »
i think the big ends and mains are ok. once i got it running correct all the rumbles disapeared. i think i need a new sump plug, where can i get one?
Offline millieman
« Reply #6 on: March 02, 2012, 07:20:35 PM »
Hi, can help with new plug.
Offline raz1966
« Reply #7 on: March 02, 2012, 07:31:10 PM »
yes please
