Author Topic: Rear Belts for Coupe?  (Read 2149 times)
Offline Tony B
« on: July 08, 2012, 08:23:15 PM »
Hi,
I guess I'll never make CID! I just realised that my ie. doesn't have rear seat belts and I was wondering how easy / hard to put this right??? What's the legality of this given it's an 82 car???
Any help appreciated  :-\
Tony B.
Re: Rear Belts for Coupe?
« Reply #1 on: July 08, 2012, 08:53:45 PM »
It should be very easy to retro-fit.
The fixing points are one pair in the middle of the rear seats, one each side under the rear armrest and one in each of the top corners of the rear parcel shelf.
The rear parcel shelf should have to large plastic screw in finishers already in place, just remove those and bolt in the replacement seat belt anchor. Less than an hour to retro-fit I'd say.
Although someone on here found they were missing one side anchorage point !
Mandatory Seat belt fitting in the rear became law in the UK in 1989, if they are fitted they MUST work.
« Last Edit: July 08, 2012, 08:55:55 PM by MattNoVAT »
Offline Tony B
« Reply #2 on: July 08, 2012, 09:13:02 PM »
Hi Matt,
Nice one - knew you'd know the way! I'll post a note - see if anyone's got a set! Might want the kids in one time and would not even contemplate carrying them without them.
Regards,
Tony
