Hi,
I've been helping Alex get this car sorted and I was hoping for a good weekend. But alas it was not to be. So to answer some questions:
1. Was the new engine definately running prior to being transplanted into your HPE? - As far as we know, yes. Although the head that came with the engine in not being used at the moment.
2. Is it Carb or Fuel Injection? Carb - From a previously working engine. Changed the carb with one from a running car too just in case. The Manifold is damp with petrol so I'm sure the carb is working.
3. When it turns over, is there any knocking noises at all? - No, it sounds smooth.
4. Is the earth strap connected & well grounded? Yes, everything is grounded as it should be. We have Spark, fuel, etc. Have tested the fuel pump, even used an electric pump just in case.
5. Has the dizzy been removed at any point? not just the cap but the whole thing (has it been put back in 180 degrees out?)
The Dizzi has been removed and replaced. Should not be 180 degrees out, however when the timing has been set it is making contact with No1. What are the correct timing positions? The Crank pulley mark sets the engine at just off No1 TDC, on a downward stroke. Have set the two cam pulley's in the correct positions, both holes lining up with the marker. This could prove to be the problem as I read on a post in the forum that it fires on 4 at TDC and not 1, however that is talking about the 2000, so I would like confirmation on this. Do you have any pictures of the timing settings on the 1600?
I'm hoping this is a simple problem of the timing being off and not a compression issue and requiring the head change, but I will test the compression on Thursday evening when I'm next at the workshop. Do you know what the values for the compression should be?
Thanks for the info so far.
