I thought i would report back from my rolling road session to cure hesitation, garage says car runs perfect but the throttle cable started to break and was sticking all over the place so had to drive back home with elastic bands pulling the carb closed , as you can imagine this isno way to test car but car certainly felt good but not totally convinced yet, after reading about the ignition system problems i think this is more likley to be my problem, have fitted new cable now but also in process of fitting speed sensor to speedo cable (classic rally) so not in position to road test, will let you know asap, Question, can you fit new electronic internals fromm h & h ignition yourself.
