Author Topic: Engine Dampers - Alternative parts  (Read 58138 times)
« on: September 10, 2012, 12:06:43 PM »
If you want to replace your failed engine dampers you can purchase from the following sites:
Cam Belt (R.H) side Engine Damper OE Part Number: 82323829
http://faparkes.epicoriscala.com/Default.aspx
FA Parkes Stock Code: 42787
Supplier stock code is: 2611YY
Use the Search facility and use the Supplier (Stabilus) Stock Code 2611YY as the criteria.
Gearbox (L.H) side Engine Damper OE Part Number: 82323831
Use Ebay and search under item number: 250836085717
http://www.ebay.co.uk/itm/MERCEDES-200-300-C-E-G300-DIESEL-ENGINE-BELT-DAMPER-/250836085717?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3a66feebd5&_uhb=1#ht_2130wt_922
The only modification you have to make is to drill out the damper mounting bushes from M8 to M10 - This can be done with a SHARP 10mm drill bit and a decent drill.  Let the ally bush cool after 30 seconds of drilling and repeat until you have drilled right through the bush.
« Last Edit: September 13, 2012, 09:31:26 AM by MattNoVAT »
Offline KrissEB
Re: Engine Dampers - Alternative parts
« Reply #1 on: May 13, 2014, 09:38:06 PM »
Matt please tell me is this solution works?
I'm asking because i find in Poland this part and in description is that
this dampers have strenght 900N (Myele) and 1200N (Swag).
Is this enaugh to use this in Beta?
« Last Edit: May 13, 2014, 09:52:54 PM by KrissEB »
Lancia Kappa 2,0 16v
Lancia Y10 Avenue 1,1
Lancia Beta HPE 2,0
« Reply #2 on: May 14, 2014, 05:41:00 AM »
Yes,  I have these fitted to my S2/FL and have had no issues.
There were approximately 26 other forum members that used these when I did the "group buy" so maybe others who have fitted them can provide some feedback (if they have actually fit them that is)  ;D
Offline KrissEB
« Reply #3 on: May 14, 2014, 07:49:49 AM »
Thanks Matt - it's great news :D
Thaks for your stuborn and patience in research:)
Lancia Beta HPE 2,0
« Reply #4 on: May 14, 2014, 08:52:00 PM »
Yes, I had the dampers fitted while the CV boots were being changed for the MOT. Both old dampers were seized solid. The new ones made a noticable difference to drivability. They had to be packed out with washers as the bushings are narrower that on the originals.
I had drilled them out as above, but it took ages with my DIY drill & admittedly cheap drill bits.
