Not a lot of progress due to elderly parents needing support and due to positive test having to isolate etc. (I was part of family group, did not have test, but assume all 4 of us, sister mother and father, were exposed and hence had it). As it happened mother and father had jabs a few weeks before and both myself and sister had no symptoms. She suspects she had it back in March 20 before last lockdown and me, well maybe I had been exposed before, who knows. Mother and father had mild symptoms thankfully. All back to normal now, my jab is this coming weekend.
Ok, enough of that. I have now managed to fit the new brake master cylinder, not fully bled the system yet, but there is fluid in all the system and a bonus is that the servo appears to work which was in unknown.
Also after a false start with bug in latest version of IOS, I have run up the AEM X-WI-FI and had a look at the mixture levels with the car idling and as expected it ran rich when first fired up at between 10 and 11, then when the choke comes off it ran very lean on small throttle opening, too lean to keep going, but in excess of 15, keeping the revs up resulted in around 12-13 which is what I was expecting to see. So the carb is coming off and the idle jet etc is being cleaned again....
