Betameeta 21 attended and nearly 400 miles added to the car. Only failure was on the way back I noticed the temp gauge was reading high and then noticed the heater which is normally on all the time, was cold. Stopping at a services and lifting the bonnet was not so pleasant as obvious water over a part of the top of the engine. After cooling and refilling the coolant, a pin hole due to corrosion was obvious in the top water rail. Luckily it was near the radiator top hose, so I loosened the jubilee clip and slid the hose further onto the rail to cover the pinhole. After that the temp behaved itself and the trip home was completed without incident thankfully.
Hopefully no lasting damage, though I shall test the compression, drain and refill the coolant and check for any oil and keep an eye on the oil fill cap and inside the fill hole for signs of water in case it has warped the head running with reduced coolant.
Lastly just a quick thanks to Alex for organising the weekend, I for one enjoyed it very much and was good to meet folk, some new and some I had met before.
