Author Topic: No pressure after MC rebuilt  (Read 4433 times)
Offline lukasdeopalenica
« on: December 03, 2012, 11:02:25 AM »
Hi Guys,
After rebuilt of my brake system (new hoses, new seals at calipers and master cylinder) my brakes literally do not work at all. I tried to bleed the system, but it seems that the pump can not built the pressure and does not suck the fluid from the reservoir. Eventually I filled the hoses and calipers gravitically, just opened subsequently bleeding screws and waited for the fluid to come, and came at all points. Should the MC be bled additionally? I am almost sure, but not sure of course I have reassembled the MC correctly... I would be grateful for any tips :)
Subaru Outback 3.0R
Re: No pressure after MC rebuilt
« Reply #1 on: December 04, 2012, 09:38:22 PM »
No one knows?  :-\
Subaru Outback 3.0R
« Reply #2 on: December 05, 2012, 08:20:51 AM »
As you have filled the system with fluid then I would start by checking the master cylinder first to ensure that it has been rebuilt correctly.
thecolonel
« Reply #3 on: December 05, 2012, 10:18:33 AM »
Dry rebuilds can cause the seals to flip over
the first time the pedal is pressed.
Pain in the butt, but does happen I'm afraid.
« Reply #4 on: December 05, 2012, 02:56:32 PM »
It sounds like that. Thank you. So I will disassemble the mc once again...I hope the seals are still in working condition ;)
Subaru Outback 3.0R
