With the on-going saga still going with the running of my dads 1600 hpe, I've come across the latest possible cause. It's just had the Carb overhauled and is running not too dis-similar than before, but at least it's been checked over professionally, cleaned, new gaskets etc so it's definitely not the carb.
On trying a brand new coil that showed to spark, the car would just not start. Re-fitted the original and it fired up. Went back to the new and it wasn't having it. So back on with the original and let it run upto temperature. Through the whole time, auto-choke worked correctly but still giving the symptoms of missing and struggling to accelerate smoothly.
I dis-connected the vacuum pipe from distributor to (back? nearest engine) of the carb and it didn't miss and seemed to accelerate smoothly...
I presume this is some type of vacuum advance unit for the ignition? Has anyone experience one breaking down, and what to expect? Just seems odd that if it had failed would that not be similar to not being connected.
You guys may have a better idea
Marcus.
