Author Topic: Unable to post  (Read 64214 times)
Offline Thotos
  • Theo Kyriacou
    • Lancia Gamma Consortium
Unable to post
« on: January 03, 2013, 12:06:13 AM »
Unable to post guys and get the error message:
Database Error: MySQL server has gone away
File: /data01/betaboyz/public_html/forum/Sources/Subs.php
Line: 2989
PS but this posted OK!  :-\
Theo Kyriacou
Re: Unable to post
« Reply #1 on: January 03, 2013, 10:58:05 AM »
What Board/Thread were you trying to post in?
Offline Thotos
  • Theo Kyriacou
Re: Unable to post
« Reply #2 on: January 03, 2013, 02:05:55 PM »
It was in the 2013 events section about Brooklands New Year's Day gathering (http://www.lanciabeta.co.uk/forum/index.php?topic=2075.msg12430#msg12430). The post was very similar to my post on the LMC forum at http://www.lancia.myzen.co.uk/forum/index.php?topic=5593.msg40153#msg40153. I tried the post several times and it failed on all of them with the same error message.
Theo Kyriacou
Re: Unable to post
« Reply #3 on: January 03, 2013, 03:05:41 PM »
If your refering to your post on the LMC website that has nineteen photos in then yes, it will fail.  On the LBF there is a limitation to eight photos per post.
Also, I am not sure what the picture size limits are on the LMC forum, but you could be falling foul of that too.
Offline Thotos
  • Theo Kyriacou
Re: Unable to post
« Reply #4 on: January 03, 2013, 03:09:33 PM »
The pictures are simply URL pointers to an external gallery. I thought limits only apply to pictures attached to the post. There should be no physical size limits to the pictures as they are not stored with the message and the display size was limited to 800 pixels wide.
Theo Kyriacou
    • My Flickr photo sets
Re: Unable to post
« Reply #5 on: January 03, 2013, 08:19:25 PM »
Hi Theo
As Matt says the limit for attached photos is 800x800 with a file limit of 900kb
but as you say they are hosted on another server, I have increased the number of attachments per post to 16, just in case SMF counts these as an attachment ??
Try it posting again, to see if this works ?
cheers
Tony
EDIT: Theo just checked the size of your pic's on the LMC Forum and they measure 1600x1200, try using a reduced size of 800px wide I'm sure that will work ?
« Last Edit: January 03, 2013, 08:24:18 PM by TonyLanciaBeta »
1981 Beta Coupe 1600
Mk7 Golf Gti
Offline Thotos
  • Theo Kyriacou
Re: Unable to post
« Reply #6 on: January 03, 2013, 09:37:41 PM »
I tried again and got the same error message.  :-[
Then I tried shortening the post and having just the one embedded photo and it worked  :D
I think the problem is the time it takes for long posts to be posted. You can try setting "Use a persistent connection" under the server settings core configuration. That should keep the server connection active to increase performance. On the other hand, nobody else had a problem so just ignore me and do nothing  ;D
Even though the photos are 1600x1200 they are embedded with [img width=800]<picture URL>[/img] so the displayed size is 800 pixels wide.
Theo Kyriacou
