Author Topic: Brake Fluid  (Read 4217 times)
Brake Fluid
« on: February 27, 2013, 08:27:52 PM »
Another very basic one - you will have to bear with me.
Is Dot 4 synthethic fluid suitable?
Thanks.
Re: Brake Fluid
« Reply #1 on: February 27, 2013, 09:09:29 PM »
DOT 4 is a mineral base not silicone base and it is stil available
DOT 5 is silicone based
DOT 5.1 is (I think) synthetic non silicone and might be OK - Please check this before using it though!
Offline millieman
Re: Brake Fluid
« Reply #2 on: February 27, 2013, 09:50:34 PM »
Have been using 5.1 for last 15 years with no probs.
Re: Brake Fluid
« Reply #3 on: March 12, 2013, 07:22:16 AM »
DOT 5.1 is a thinner mineral fluid designed for ABS and will work fine having a higher boiling point as well. However careful choice of the right DOT4 fluid can give a harder pedal with better feel and a similar high boiling point. After a lot of trial on Montecarlos where brakes are a bit of an issue ATE super blue and Motul RBF600 are good choices but there are several other good choices.
