Author Topic: advice needded  (Read 4583 times)
Offline raz1966
advice needded
« on: March 12, 2013, 06:21:42 PM »
i have not been using my car much recently but now i would like to start using it.
the trouble i have got is everytime i leave it for a few days its hard to start. i have noticed the fuel filter is full of petrol when i leave the car after using it but after a day or so the filter is empty and it wont start.
if i take the air cleaner lid off and poor a little fuel down the carb it fires up and the filter fills up and it runs ok.
i guess the fuel is evapourating from the carb when its left, any ideas why?
thecolonel
Re: advice needded
« Reply #1 on: March 12, 2013, 08:26:21 PM »
More likely the fuel is being drawn back to the tank.
easiest solution : fit electric pump and prime before
starting.
Geoff
Offline raz1966
Re: advice needded
« Reply #2 on: March 12, 2013, 09:16:32 PM »
I don't want to fit an electric fuel pump, I want to keep it origianl
Re: advice needded
« Reply #3 on: March 12, 2013, 11:10:51 PM »
This topic was discussed at length before. search for 'fuel draining away'
May give you some clues to what to look for.
Re: advice needded
« Reply #4 on: March 13, 2013, 09:00:36 PM »
The membrane in your pump is shot. As Peter points out the subject was covered at length not long ago.
Offline raz1966
Re: advice needded
« Reply #5 on: March 19, 2013, 08:11:34 PM »
membrane is new, i think the fuel line were letting air in, problem has gone now
